RPM go up slower then before????
Old 10-11-2002, 11:17 AM
b8b88's Avatar
Default RPM go up slower then before????
I have 35000 miles on my car. IM using mobil1 0w40 right now. Is it the engine oil problem or somthing else?
IS that oil too thick for my car? (slower)
Old 10-11-2002, 11:46 AM
twohoos's Avatar
Unngghhh!! Lothar think 10w30 best oil for you!
Old 10-11-2002, 11:54 AM
b8b88's Avatar
so you mean its the oil problem???
Old 10-11-2002, 12:02 PM
RWD_RCKT's Avatar
Me Grimlock... agree with twohoos... 10W-30
But seriously I don't think that is why you car is slower. It has got to be something else....
Old 10-11-2002, 01:43 PM
xviper's Avatar
You should tell readers what all else you've done to the car (like the straight pipe thing?). Then maybe people can make an informed comment for you. It may not just be the oil.
Old 10-11-2002, 02:19 PM
b8b88's Avatar
I have ingen intake, comptech header, costom straight pipe, HKS exhaust, denso spark plugs, and have used mobil1 0w40 for about 10000 miles. Right now I have 35000 miles on my car. SO, is it the oil problem or something else
Old 10-11-2002, 02:45 PM
xviper's Avatar
Did you first notice this right after changing to a 0W40? Are your plugs torqued down properly and have the correct gap? They have been known to back out if your are still using the original 13#s. All plugs have a revised torque of 18#s now. No need to tell you what a bad gap can do.
Old 10-11-2002, 03:14 PM
b8b88's Avatar
i use denso ik22 spark plug, not sure what they pre-gap at. whats the right gap for our car? when i first use 0w-40 i did notice a little lag of the rpm. yesterday i raced with my friend's stock s2000 from 80-120mph...we were pretty much the same. thats when i really notice the rpm probelm. thanks
Old 10-11-2002, 03:21 PM
xviper's Avatar
Stock plugs should be about 0.040. The Densos should be set to this too. I'm not sure I understand why you're using 0W40 in California. Go back to 10W30 and go with a full synthetic if you can afford it.
Old 10-11-2002, 04:44 PM
b8b88's Avatar
I just change my oil to mobil1 10w30 today. Dont have the time to test yet. May the wrong gap of spark plug make the RPM go slower ??
Quick Reply: RPM go up slower then before????
