royal purple oil
Originally Posted by VAD,Oct 24 2006, 01:18 PM
Some RP UOA's from bitog:
http://theoildrop.server101.com/forums/sho...ge=4#Post724540
http://theoildrop.server101.com/forums/sho...ge=8#Post255683
http://theoildrop.server101.com/forums/sho...e=23#Post252320
http://theoildrop.server101.com/forums/sho...e=23#Post252195
Now you can make up your own mind whether or not "it sucks". The owner of bitog uses RP 15W40 in his truck, too. FWIW. So if you use it in your car, you're in pretty good company.
My only question. You provided 4 links. How many links did you have to go through to find them?
Did they do anything different in the last 5 years?
Originally Posted by Jasonoff,Oct 25 2006, 07:12 AM
Now THATS interesting. I admit it's been quite a while since I've looked at anything. But I clearly remember the RP brand being trashed over and over on that site.
I run a dry sump system on my F20C engined kit car and tend to change my oil every few thousand miles as most of those are done on the track and have had no problems with Royal Purple though I still prefer Motul 300V 5W30 but I would happily recommed RP to anyone.
I'm going to go with Mobil 1 AFTER the first oil change @ 7500mi confident that it probably can't get too much better. Realistically though, I doubt it makes much difference. Use any major brand at the recommend weight and the results are probably the same provided scheduled changes are observed.
Certain brands give us a sense of security which is good and may be the main reason why we should use only brands that make us feel this way. Weather it's RP, QS or Pennzoil, and the oil feels right to you, that is the only thing that counts.
