Rough Idle, otherwise running well
Old 02-14-2008, 10:39 PM
AusS2000's Avatar
Swapping them to another cylinder will though.
If you're getting a misfire on a certain cylinder and you swap injectors and the problem moves with it then you know it's the injector. If the problem stays put it is something else.
Old 02-15-2008, 04:44 AM
CKit's Avatar
He did say random misfire code, though.
Old 02-15-2008, 05:53 AM
S2Kart's Avatar
If its running well but only idling rough it might be the TPS sensor also.
Old 02-15-2008, 02:00 PM
RedY2KS2k's Avatar
Originally Posted by silvers2k01,Feb 14 2008, 07:45 PM
MAP not MAF!!
I know. That's why it would be so hard to find the Mass Air Flow sensor on the S2000.
Old 02-15-2008, 04:22 PM
CKit's Avatar
It's right next to the power steering pump and the VTEC fluid.
Old 02-16-2008, 11:52 AM
RedY2KS2k's Avatar
THAT's why I couldn't find it. ;-)
-Matt
08-26-2015 09:24 PM
daicacharco
01-04-2011 10:13 AM
s2kbad
02-15-2007 03:21 AM
marcucci
11-30-2003 03:09 PM
Quick Reply: Rough Idle, otherwise running well
