Rough Idle and CEL
Bosch +4's are deff. the WORST plugs I have used in my life on any car. The moment I got them, my old car started developing misfires. Changed it over to copper core 2dollar plugs and it went away. NEVER will buy bosch plugs again, after that terrible experience. It also fouled up in a week to the point where it was BLACk, BLACK.
NGK copper core has always done right by me, but in my s2k I'm running the OEM spec'd plugs.
Just did a compression test, results came back:
1:270
2:255
3:255
4:260
It is a little lower in cylinders 2 and 3, dont know if this is related to what has happened or not but they are decently close so i dont think i have anything to worry about there.
I am still wondering about the coil packs. If you look at the pics in my origial post they looked real bad but i cleaned them as you can see in the last picture.
They seem to be running fine, i feel like they just got dirtied up and discolored form the loose plugs. Bottom line, do you think i need to replace them?
Thanks
1:270
2:255
3:255
4:260
Thanks
1:270
2:255
3:255
4:260
Thanks
1:270
2:255
3:255
4:260
Thanks
those exact plugs did the same to my f20c engine and mine had worse results, scratched my walls, block was toast, but now i got the f22c so i guess it was for hte better..
Worse Plugs EVER.
Only u NGk
Worse Plugs EVER.
Only u NGk
they do not dissipate heat very well so the heat range is unpredictable
stick with NGK
I dont think i need to replace them. They're runnin fine i think theyre just discolored.
Im just wondering, is there a replacement interval for them? like at 100K miles or something like that because if there is i might just swap them now
Thanks
Thanks
