Rough Idle, Bogging on Takeoff, Upper RPMS are ok
Old 01-14-2009, 10:49 PM
bioman's Avatar
Does anyone have this problem AFTER getting the zip tie TSB fix?
Old 01-14-2009, 11:33 PM
jzz30's Avatar
i had 2 costomer cars come in with the exact same problem. one of the cars i swapped coil packs plugs and map with mine. it didnt change, the check engine showed misfire codes in all 4 cylinders. it turns out the valves were out of adjustment. one of the adjusters were actually loose. the second car naturally we just adjusted the valves right off the bat and the idle was smooth as butter.
Old 01-25-2009, 07:55 AM
edhs2k's Avatar
do a compression test. I had the same problem,turnde out to be bad valve guides and sticky valves.
Old 02-04-2009, 01:48 PM
hondanc7's Avatar
I have this EXACT same problem!! I dont wanna hit the MAP too hard and crack it or anything ha. But this problem is really annoying especially when you are in traffic and afraid the car may shut off.
Old 02-04-2009, 11:04 PM
integlspwr's Avatar
jons car had the same exact problem.. but fixed with a valve adjust.
Old 02-05-2009, 06:14 AM
hondanc7's Avatar
Took mine to the dealer today and they couldn't think of anything it could be except blaming it on my K&N intake. They said if it was the MAP sensor the CEL should be on though.
abarca54
05-01-2014 12:10 PM
mitch028
01-02-2014 04:30 PM
Sub_01
09-19-2008 07:46 AM
jamal
11-20-2007 04:04 AM
josh3io
02-26-2002 08:16 AM
Quick Reply: Rough Idle, Bogging on Takeoff, Upper RPMS are ok
