Rough idle after TCT fix?
I just sandblasted my TCT the correct way and put it all back together exactly how it said too on the DIY. Now when I put my car in neutral if im rolling or have to do a quick 5 feet drive than stop the RPMS dip to like 200 and almost cuts off. Any ideas?
I did not disconnect the battery, the TCT was out of the car for a day and a half I kept the opening covered so nothing went in or out of the hole.
Funny...I had the same issue that you're describing.
Did you re-install that oil plug bolt? It goes on after you remove the bolt that you lodge in to compress the plunger. Reason I ask is because I was guilty of this. Finally figured out that I left out that oil plug bolt. And, the idle returned to normal after I installed the plug bolt. No damage, knock on wood.
Onehots2k
03-13-2009 05:39 PM
