Rough Idle
Rough Idle
So as the title says I have been having rough idle(100-200rpms) at dead stops and most of the time the car dies. This has been happening throughout the year and it comes and goes, I usually notice that it happens on warm days after I vtec or sometimes just happens randomly on warm days. So far I have have cleaned the IAC valve(did this about 2-3 weeks ago), cleaned map sensor, maf sensor and have recalibrated the ecu a bunch of times but this dam rough idle keeps coming back and its starting to happen more frequently and its super annoying! I have an k&n fipk intake I have cleaned the filter but I think im gonna try and clean it again(maybe this will help?). Also when I was looking at my engine bay I found this around the head area, im not sure exactly where its coming from but it might be part of the problem? Or maybe another problem? lol
I know alot of people have had this problem if so if anyone can share their experience or if anyone knows my problem it would be GREATLY appreciated!
-Thanks
-Thanks
To start, we don't have a MAF (mass air flow) sensor, so IDK what you cleaned.
Any codes? Dirty filter could cause it, bad fuel injector, map sensor, iat sensor, iac valve. Data stream via a scan tool would work very well for this problem, but I don't expect you to have that at your disposal.
You must be talking about the IAT sensor on the intake. IAT is intake air temperature sensor. Although you cleaned those sensors and the valve, they could still be causing a problem.
Do you have a voltmeter?
Try the throttle coolant bypass. I did that on my car yesterday and my car doesn't drop under 1k at all anymore. You just block off two coolant lines going into your throttle body/intake manifold area with a couple 3/8 steel balls. This stops the hot coolant from entering and increasing your IAT
Sent from my iPhone using Tapatalk
tlogic
11-06-2009 11:03 AM
