Rough cold start in the morning
This started happening recently and I was wondering if it's normal or is there a cause?
Each morning when starting my car to go to work, it stumbles around 400-500 rpm for a few seconds until it jumps up to 2000 rpm and does the warm up routine.
I just want to know if it's bad for the car to stumble at low rpm like that and what could cause that?
I'd prolly go for a general tune-up. You know... plugs, air cleaner, timing check, general diagnostics. When was the last time you had this done?
Any chance you got some bad gas? Err... gasoline?
![biggrin.gif](https://www.s2ki.com/forums/images/smilies/biggrin.gif)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Not sure of the cause, mine has done that in the past and then it goes away, I usually run a bit of Redline fuel injector cleaner and it helps. I think it's fuel related myself.
With mine I can get the issue to stop by giving it a bit of throttle at start up, even though you aren't supposed to need to touch the gas pedal when starting.
And I'm using 100% gasoline 92 octane without ethanol.
I'd go for spark plugs and air cleaner filter. I'd use OEM NGK (7772) PFR7G-11S and factory air cleaner. Then, see what happens.
Seems that the dipping of the RPM's could be an ECU issue. Check this link:
https://www.s2ki.com/s2000/topic/386...-stalling-etc/
Good luck!
8^)
Good luck!
8^)
