Rotors are stuck
Old 09-02-2010, 08:33 PM
Opc
Opc's Avatar
Originally Posted by jeggy,Sep 2 2010, 05:14 PM
then go buy new rotors because you just bent/warped/divoted the thing by wacking it with a hammer.
lol.. who would take a hammer to rotors.. mallet.. rubber.. should be common sense
Old 09-02-2010, 09:20 PM
fatjoe10's Avatar
you only sledge hammer the rotors when you're removing them and throwing them away. Rubber hammer will not break loose an extremely stubborn rotor. I don't think some of you guys have ever seen a really stuck one yet.
If you want to turn them, the best is to push the bolts thru the hat and pull them off the hubs as previously described.
Old 09-02-2010, 10:15 PM
Seattle2k's Avatar
only if you're hitting the face of the rotors.
Old 09-03-2010, 03:47 AM
Billman250's Avatar
Received 1,401 Likes on 839 Posts
Or just run a torch around the OUTside of the studs, and the rotor will grow/expand and come off by hand. You dont even need to get it very hot. Definitely not as hot as you would get it during normal driving.
It is stuck around the center hub. Heating in a circle outside the studs allows the heat to move toward the inner bore of the rotor, without heating the center hub of the car. Even a rotor that would not come off with a 4lb sledge will literally lift off by hand.
Old 09-03-2010, 05:20 AM
ljsimp's Avatar
use a rubber mallet! The vibration of the rubber will help too.
Old 09-03-2010, 05:21 AM
ljsimp's Avatar
The wonderful power of heat! I wish I had a torch to take off many parts.
Old 09-03-2010, 07:27 AM
INTJ's Avatar
Bill is right, but I've never gotten that far. Unless you live in bad salt country I guess. They sell map torches for 10 bucks at ace.
Old 09-03-2010, 07:58 AM
mrbond413's Avatar
Haha, Well it so happens that I live in salt lake city. I didn't have a rubber mallot so I took some old rubber floor mats and shielded the rotors with them before whacking them. I tried pushing the bolts through the hat and they broke loose fairly easily after working each side a little and giving it a light tap with a hammer. Thanks for everyone's help.
Old 09-03-2010, 09:40 AM
HondaS's Avatar
I ran into this as well when i did my brakes i just hit the rotors from behind. turned the rotor till the other side was at the bottom and then i hit that and just repeat till it comes off
Old 09-03-2010, 10:42 AM
ljsimp's Avatar
Would the matt torch heat the metal hot enough u think?
Quick Reply: Rotors are stuck
