Rotor Screw
Old 10-11-2007, 04:52 AM
  #21
HMFIC's Avatar
Originally Posted by TJF,Oct 10 2007, 01:19 PM
Um... thats not what a free floating rotor is. A free floating rotor is a two-piece rotor that lets the rotor slide freely on the hat via pins.
Notice how the rotor and the hat on this pic are two seperate pieces. The rotor itself can actually move free of the hat. This allows it to perfectly center itself between the two pads as they clamp down, thereby optimizing heat and pressure distribution.
The reason no one uses them on street cars is because they are noisy as hell since they actually rattle around between the caliper (and they are expensive).
AH......that makes sense.......thanks for the info!
Old 10-11-2007, 04:57 AM
  #22
JustinC's Avatar
Originally Posted by pemex70,Oct 10 2007, 08:43 AM
I had the same fear when I first replaced my rotors on my05 but VaderS2k is correct.
I bought a few screws from Honda to be safe but I never used them. I used one lug nut to hold it in place while i reinstalled the calipers back and the brakes will hold the rotor while u put the wheel back and in turn the wheel will hold the rotor in place when the brakes are not being used.
Hope that made sense!
I did strip the first 2 screws by hand but then I used a drill to remove them. Sprayed them with a penetrating lubricant (not KY ) and held the drill firmly into the screw and it came out. Could have re-used them but decided not to.
Be careful if you use a lugnut to hold the rotor down. Most lugnuts are tapered and if you tighten it down to hold the rotor firmly it can snap the stud off if it goes too far into the taper.
Old 10-11-2007, 06:25 AM
  #23
bobushka king's Avatar
The same thing happened on my Civic, I used an impact screwdriver and broke the tip of the bit off inside the screw. 189k on the original rotors FTL
Old 10-12-2007, 09:58 AM
  #24
Drop Top's Avatar
Turns out that I have a warped rotor. I just had it turned but I guess you can still turn a rotor that's warped. Oh well. Live and learn.
s2000maniac
04-29-2011 05:19 AM
mrbond413
09-06-2010 07:49 AM
HankookS2K
10-15-2007 02:43 PM
scotishpower
04-02-2006 05:45 PM
124Spider
07-15-2005 09:39 PM
Quick Reply: Rotor Screw
