Roof latch broken.
Roof latch broken.
Today on my drive home after getting my valve adjustment done I noticed some extra rattle on the driver side latch. I am able to release it without holding down the button and it's really loose.
Here are the pictures.
Driver side:
Passenger side:
I can see that the black part above the spring is missing/ broke and that's why it it doesn't lock. Is my only solution to get a new lock assembly?
Driver side:
Passenger side:
Not sure there is any solution but a new latch assembly.
Might post in the Want to Buy forum to see if someone is parting out a car. Note: MY00-01 have different latches from MY02+ so make sure you get the right one.
I see. I have an aftermarket top though. Will the OEM one still work??
Should I just get a new one? I figure it will make the roof tighter than a used one that might fail too.
