rocket motorsports cams? (regrinds)
im sure many people know the guy behind rocket motorsports has been around forever.
and the RM24 cams for b series etc
i know hes super legit for b series parts and knows his shit. i picked his brain a few times in the past and he explained everything in great detail even though he didnt have to.
i asked him if he has anything for s2000 he told me he can do stock cam regrinds.
has anyone used his cams?
i searched here and google and came up with nothing so far
What specs are those cams? There is a cam thread that shows testing of various cam profiles only a couple made little of any power over stock cams. The only set that made enough to raise eyebrows were the ones used with the design craft ivtec conversion kit
Yes, my tuner built a head on his customers Ap1. Everything was upgraded to supertech, valves,dual springs,retainers,guides etc. The customer requested the rocket motorsport cams after seeing claims of high HP, after a few hours on the dyno all he was able to extract from the car was 202 Hp. He called me a few days later asking what my thoughts were on the low hp gains from that s2000. Compression was at 230 all the way across, leak down numbers were good and plugs and coil packs were just replaced along with a few other maintenance items. I suggested he went back to OEM cams, he was hesitant as the swap was going to be on his dime. I told him I would cover the cost of labor if he didn't see any gains. A few days went by that I didn't hear from him so I decided to call him, sure enough after the stock cams were installed and the car was retuned he was able to get 221hp out of the car. If you really want more info on these I can send you his contact info so you can give him a call, but personally I wouldn't bother with those cams
08s2000CRbackinblack
05-09-2008 05:19 PM
