Ringing at WOT?
Ringing at WOT?
Made an appointment with local dealer for wednesday evening to get car checked for a few things.
1. Drivers side window express down not working even when letting top down.
2. Grinds if I don't go in 5th before 6th.
3. 2nd gear grind with clutch fully engaged
4. Clutch rattle sound
5. At vtec tinging ringing noise coming from somewhere, sounds like from the
front
#5 is where I need you guys help. Sounds like maybe a loose not or washer or something. Has anyone ever had this and WTH is it. Almost makes me not want to go to vtec. <Yeah right Any help on this or others would be appreciated.
Thanks,
Mrcln1
front
Thanks,
Mrcln1
#5 may be a ringing shifter? Sometimes it's hard to tell where sounds are coming from.
TSB 02-046 (although for a different symptom) explains how to grease the shift lever and it's not to difficult to do. The grease dampens the ring (vibration).
You can also do a search within this forum and find more on this.
http://forums.s2ki.com/forums/index.php?showtopic=41390
BobSaget
02-19-2012 10:50 PM
