Rims are on. Handling sux ass now.
#54
Originally Posted by Spec_Ops2087,Jun 19 2007, 02:41 PM
As your tires get to be bald (or near bald), the tire compound gets much harder (to help hold the tread against the patching) which SEVERLY decresses grip.
(Track tires are an entirely different animal.)
#55
Originally Posted by Spec_Ops2087,Jun 19 2007, 04:41 PM
Common assumption, that most people make, that is incorrect.
Now if you are actually getting to the core or the wear bands, then that material is harder to prevent the tire from blowing before you're able to get them replaced. I am sure you've at least heard about serious racers shaving their tires to get the optimum contact patch and responsiveness from the tires. This is similar, but much better than worn down tires. While worn tires do have the same advantages, they are in a much more limited fashion. As tires heat up (every time you drive) there are agents in the tires that chemically bond the rubber together creating a layer of harder, denser rubber there by losing some of the grip benefits.
#56
Lower profile rear tires at higher pressure (and maybe heavier) make the rear shocks work harder.
The rear shocks can lose a lot of their performance with age and very little mileage (like five years and 30k miles). Once this happens the car will bump steer like crazy.
If you have lowering springs, the effect is even worse because of the rear toe control geometry.
MG
MG
superchrgds2k
10-24-2011 05:13 PM
