Rick's JDM Sidemarkers
Old 03-30-2006, 02:13 PM
gosixers215's Avatar
Default Rick's JDM Sidemarkers
As I was putting on the JDM sidemarker on the passenger side, I had a problem getting the clip on the back to latch all the way. It seems now that a good amount of force was able to secure it, but I can still see just a tiny bit of the clip that doesn't seem to want to fit in.
How can I fix this? Is it possible to shave off just a fraction off of the end of the clip so that it will catch? Push the sidemarker with more force? (Don't want to break it though). A small piece of double-sided tape? Thanks!
Old 03-30-2006, 04:19 PM
darkfx's Avatar
boil some hot water on the stove, then put the diffuser in the water and bend it gently to fit
Old 03-30-2006, 04:20 PM
It's not a diffuser though, it's a sidemarker. I don't want to risk leaking into the sidemarker housing.
Old 03-30-2006, 04:30 PM
r_duff's Avatar
did u put it in right? the blut side faces the front of the car and the tapered part faces the rear. No need to worry about water, the plug is grease capped, so its water proof.
Old 03-30-2006, 04:33 PM
I followed the instructions from Rick's website. The driver's side one went in just fine, but the passenger side one is being difficult. If it's sealed then I will try softening up the clip
Old 03-30-2006, 04:36 PM
r_duff's Avatar
just becareful to not break the clip.. they break easy! and make sure thy're facing the right way
Old 03-30-2006, 04:47 PM
I think softening the clip will help. It looks like it just won't bend enough to latch on to the sheet metal.
Old 03-30-2006, 04:58 PM
I just went out and checked it and it secures, but the latch on the back side isn't catching all the way (I put them in right). I'm going to take it for a quick spin to see if they come loose at any speed...
Old 03-30-2006, 05:46 PM
Ok, so I finally diagnosed the problem. The sidemarker goes in flush, but the latch won't "latch" (if that makes any sense. It stays compressed instead of latching onto the sheet metal... any way I can reach through the wheel well or anything to make sure it latches?
Old 03-30-2006, 07:37 PM
Stratocaster's Avatar
You know, we will be happy to replace this right? All you have to do is send us an e-mail and out line the problem. Without an e-mail, I don't know who you are
Quick Reply: Rick's JDM Sidemarkers
