RHS passenger power window won't roll up
Hey there
I have this problem that a few people also seem to come across. Only My passenger side window rolls down automatically when I put the top down, but then it won't come back up, I can hear the click sound but still nothing. I have checked the on off switch on driver side door In both positions but still nothing. I've checked the fuses too, drivers side works perfectly. What am I doing wrong? Ive read the other threads about this issue, please help !
Copied from s2000 forums------------I had a similar problem with my car. Let's see if I can remember this right. It might be a trial and error thing. But someone told me to put the key in the ignition in the ON position and hold the window button down until you hear a click sound. This resets the module to open/close the window. You can do it for either window. I think I had this problem when I lowered the top, the windows would not go down with it.___OR---- Thanks for the tip, it didn't work, but while I was screwing around I discovered that I had inadvertantly hit the window lock switch. I guess it only regulates the passenger window.
