reverse light switch, and wiring check
Hey guys, my reverse lights are out, and I've listed out below the things I've checked. I have the pdf wire daigram from the book. Here are the circuit basics...The Ignition switch provides 12v to the 7.5 fuse in the interior fuse box, which then routes through the backup light switch to the bulbs, after the bulbs the circuit is grounded.
interior "back up" fuse - not blown
ignition voltage to fuse - good
Reverse light switch continuity - 39ohms, shouldn't it be a solid connection?? Should still light up the bulbs though
reverse light bulb - new
reverse light bulb 12v - no voltage (tested with the harness jumpered, bypassing the reverse switch)
reverse light bulb ground - good
I've put the tail lights PDF in my dropbox. Click the link below.
https://www.dropbox.com/s/61mb95ts35...ights.pdf?dl=0
jpark
04-17-2023 04:00 PM
