Reverse gear popout, anything I can do to check it out or is it f'd?
MY03, about 98k miles, new tranny fluid within the past 6k miles, I can shift it into reverse, but as soon as i give it gas and let off the clutch, immediately spits it back out. Is there anything I can check up on/look at/fix myself, or is it pretty much f@#ked and I need a rebuild or a new transmission? Thanks for the help guys.
Original OEM clutch, used Honda transmission fluid from hardtopguy.com when I changed the fluid. The rest of the gears seem to shift fine, smooth, no pop out problems, engage fine, just reverse.
