Rev limiter at 6000!
Old 11-05-2005, 03:22 PM
Eluded's Avatar
confirmed, no vtec here either for last two days
Old 11-05-2005, 03:59 PM
Slows2k's Avatar
There is no serviceable fuel filter on a s2k.
If the CEL is on for a VTEC failure (P1259) you will have a low max rpm rev limit untill the CEL is cleared.
Something isn't right here. If the VTEC solenoid or pressure switch is unplugged, you'll have a CEL after startup, with the P1259 stored.
Are there any other modifications to the car?
Old 11-05-2005, 06:26 PM
Wisconsin S2k's Avatar
[QUOTE=Slows2k,Nov 5 2005, 06:59 PM] There is no serviceable fuel filter on a s2k.
Old 11-06-2005, 04:13 AM
Latif's Avatar
i do have the P01259 .... once i clear it the rev limiter is back to 9000 rpm.. after a few minutes the limiter is at 6000 rpm and the code appears again!!
Old 11-06-2005, 05:40 AM
and you didn't think to mention that when you first posted? lol sheesh
you need to take your car to a dealership to get it fixed. you could have a bad VTEC oil pressure switch, or a bad VTEC solenoid. or a loose connection somewhere.
Old 11-06-2005, 07:28 AM
Slows2k's Avatar
It's perfectly normal to have a low RPM rev limit with the P1259. Low oil pressure, and a clogged VTEC inlet screen can also cause it.
If the Inlet screen is clogged, the oil has not been changed regularly.
Old 11-07-2005, 11:01 AM
Latif's Avatar
I have sent the car to the dealer .... hopefully by tomorrow they should tell me what went wrong .....
Old 11-07-2005, 03:37 PM
Inlands2k's Avatar
i have the same prob once in a while. but i turn the car off and then start it back up and its back to normal! wonder what it is. keep us updated!
Old 11-09-2005, 08:51 AM
Latif's Avatar
the dealer told me i didnt have any problems with the vtec solenoid nor the oil pressure switch. they were baffled to what could cause this and couldn't give me an answer. I took my car went home and started to check all the connections from and to the vtec solenoid, and one of them was loose!! got a cable tie to make sure it stays tight in the switch and now my car is back to normal!!!
Old 11-09-2005, 01:19 PM
tenchi950's Avatar
Sometimes you gotta reset the ECU. Discconect the battery for couple of mins, then turn back on, let it idle for about 5 mins.
Quick Reply: Rev limiter at 6000!
