Retrieved ABS DTC's - Need Help
Hi all, I just got my 2003 s2k a month or so ago and have been trying my best to make sure to make the car runs as smoothly as possible. Since I bought the car the ABS light would come on sporadically and turn off whenever it wanted, but a few days ago the ABS light came on and has been constantly lit. After reading through the forums I pulled the codes by jumping the DLC and got codes 15 and 81. From what I could find code 15 means a right-rear wheel sensor short and code 81 means an issue with the ABS CPU(?).
I am not really proficient at working on cars but I am learning slowly but surely and was hoping someone could point me in the right direction so I could attempt to fix this issue myself. Perhaps learn a few things as well
https://www.s2ki.com/s2000/topic/808...-speed-sensor/
http://www.popularmechanics.com/cars...enance/2265091
You can try checking the impedance with a multimeter. I don't know what the normal impedance is on a sensor. You can always compare it to the other side.
Thanks for the links, at least now I have somewhere to start from. Now I just have to try and find a friend with a functional multimeter because mine is taking a dirt nap.
For code 81...
Clear the DTC. Then test-drive the vehicle.
If the light does not come back on with the same code its an intermittent failure and its okay.
If it does come back on , you need to replace the ABS modulator
