Reset check engine light with actron scanner now car won't start
Had a p0411 code had the car on with the scanner plugged in and wasn't thinking and erased the codes while the car was still on right when I clicked erase car started to sputter then died now won't start I checked the ecu fuse and fuel pump fuse there both good and i disconnected the battery for a good 5 mins ..still won't start thinking maybe I messed up the immobilizer in the key does anybody have any other ideas ???? Kinda stumped
Can you jump start the car?
Sometimes an ecu fault will keep the car from starting on it's own even if all the systems check out. See if you can jump start the car, if you can, then see if you can start it again on its own. It could be a ecu fault if it only starts with a jump start
Mr. Francesco
04-02-2013 06:37 PM
