Replacing Prop shaft allen bolts
what I found works real well is grind down your Allen key so you get less deflection and it also gives you a clean hex head to use. Also clean out the heads real well of all road debris and factory undercoating
Ian300D (08-17-2021)
Slim long handle 1/4" ratchet and a stubby 6mm hex socket. Easy peasy.
