replacing knock sensor.
Old 12-09-2011, 10:34 AM
  #31
BrockB's Avatar
ok thanks
Old 12-09-2011, 06:48 PM
  #32
ry4nolson's Avatar
You should be able to just feel up past the start and find it. Look at my pics on the previous page for location. It should be fairly obvious to feel if it's broken or not.
Old 12-13-2011, 06:46 PM
  #33
ajm
ajm's Avatar
When you replace the knock sensor was there a rubber boot over the sensor protecting it?
When you took off the wire harness, did it just pull off, or did you have to twist it or pinch it to get it off?
ajm112446@virizon.net
ajm112446@gmail.com
Old 12-13-2011, 11:39 PM
  #34
ry4nolson's Avatar
ajm112446@gmail.com
My sensor was completely broken so no i didn't have to twist or pinch. You should have to squeeze the tab just like any other connector though if your sensor isn't broken.
I don't think there is a rubber boot on it but I don't remember. Here is a picture of the connector (with the green piece)
Old 12-14-2011, 04:51 AM
  #35
ajm
ajm's Avatar
Thanks, I appreciate your help
Old 06-13-2012, 11:12 AM
  #36
HellaS2K's Avatar
I know this is old. After searching...this thread comes up the most. I want to end the confusion. I went to autozone today and got a 99 oddessy knock sensor. I can confirm the plugs are the same, and the colors are different.
I am about to install as soon as my car cools down. I WILL update.
Old 06-13-2012, 11:17 AM
  #37
HellaS2K's Avatar
Old 06-13-2012, 03:27 PM
  #38
HellaS2K's Avatar
Confirmed. They are the same, shape, size, and threads.
I installed it, and no more check engine light.
Old 06-13-2012, 04:41 PM
  #39
CoolGuy094's Avatar
Awesome, good job. This happened to me during a clutch install as well. What was the cost savings on the Odyssey part versus the S2000 part?
Old 06-13-2012, 05:37 PM
  #40
HellaS2K's Avatar
It was like $47.00 for the oddessy
Vs
$160!!! For the s2000
Quick Reply: replacing knock sensor.
