Replacing Front End Slam Panel
Front end collision, need new front end slam panel...
Need help taking off the old one and putting new one on to cut costs...
http://www.ebay.co.uk/itm/Honda-S200...c#ht_500wt_707
God it pains me to throw this up...
Will def. have to cut it...
But maybe you can give me some more insight in what im looking at as far as repairs.
It's hard to tell from the pics but it actually doesnt look too bad. The very front upper piece that bumper attatches to is a bolt on piece so that should take care of that and the lower portion is held on by a couple of small welds. I wouldnt buy that whole front peice thats on ebay. You can probably buy what you need specifically from the dealer for less. You'll need the bumper support and you can probably find that used for around 50 bucks and you also may need other small brackets but for the most part its a quick fix.
If you're looking to do some of the work on your own to save money try take everything off thats in the way and drill out those welds and just have a shop weld the peice. You can probably get it done super cheap if you know anyone that has a connection at a body shop.
I wud be down to drill away but i wudnt know how much to take away....I'm geussing anything behind the bend. I will take some better pictures tmrw.
Luchak
10-13-2005 07:11 PM
hams2k
10-25-2002 06:38 AM
