Replacing a door lock
Any body have directions on how to replace a door lock? I have to change the lock becasue I am replacing a damaged door and can't figure it out. Any help would be appreciated!!!!!!!!!!!!!
Thanks
Thanks
See Majestic Parts illustration.
Raise glass fully
In order, remove:
Item 52, screw
Item 21, rod protector
Hole seal (an oblong seal over the lock area)
Item 7, rod holder
Cylinder rod (squiggly rod in upper right of picture - disconnect but leave in place)
Retainer clip (a wire circlip-type retainer that holds the lock cylinder in place)
Item 39, switch assy
Item 23, lock cylinder
Raise glass fully
In order, remove:
Item 52, screw
Item 7, rod holder
Does anyone have any idea how the harness clip, item 8, is disconnected from the cylinder switch? Does it just pull off or does it slide down to release? I can't quite figure it out and I don't want to break it. ????????????????????
