Replacing Differential Mount
Hi guys,
I've been looking to replace the differential mounts(mine is current leaking). I want an oem feeling with no vibration. Which Innovative Mounts should I go with 60A or 75A
Umm Oem is pretty good and not too expensive. Very easy to change, especially if you're not lowered.
Hardrace ftw though, their hardened rubber bushings are at a good price. I used their hardened rubber bushings since they're as good as Oem and around the same price. Plus they're more readily available.
I use 75A rear innovative diff mounts and there are zero vibrations. You will more likely get vibrations from the engine/transmission mounts.
I was able to get the full set of diff mounts for ~150 shipped. They have been excellent since I've put them on and held up on track.
E4RTH WORM JIM
08-29-2017 06:18 AM
