Replacing cracked oil pan
Old 02-11-2006, 01:18 AM
jzz30's Avatar
Hondabond!!! the motor is put together with that stuff so you might as well use the same thing rather than something else that may fail.
Old 02-11-2006, 07:18 AM
RT
RT's Avatar
Yamabond works too if the Honda stuff is scarce.
Old 02-11-2006, 07:21 AM
RT
RT's Avatar
Originally Posted by F20C PWR,Feb 10 2006, 12:51 PM
what's the sealant called to put on the oil pan? Honda bond? RTV ?
Hondabond is an RTV but not all RTV's will do the job (lots of products considered RTV's).
RTV = Room Temperature Vulcanizing
Old 02-11-2006, 07:22 AM
esoteric's Avatar
Hondabond is just permatex.
Old 02-11-2006, 07:27 AM
RT
RT's Avatar
Originally Posted by moto2K1,Feb 8 2006, 10:26 PM
I was just curious if it is safe to drive the car right after installing a new oil pan. .............................. I don't want to hang out at a quick oil change joint for a couple of hours.
-jason
The stuff sets up pretty quick but doesn't "fully" cure for a longer time period. If you don't live too far away you could risk it and just drive it home gentally (if it were me I'd risk it no problem).
The real issue/question is if you want the same jokers that cracked the pan to strip out the holes in your block when they install the new pan, cause they will
Old 02-11-2006, 07:31 AM
RT
RT's Avatar
yeah, but which one? Permatex makes some good stuff but they also make stuff that won't hold up for the oil pan installation .......... stick with the stuff Honda calls out (which is very close to the Yamaha stuff in my experience)
pininfarina456
03-15-2008 05:07 PM
news2kroller
06-04-2004 06:57 PM
Steve2K
10-30-2002 03:32 PM
ok2k
03-23-2001 05:13 AM
Quick Reply: Replacing cracked oil pan
