Replacing Clutch~ Average Cost?
I'm thinking about changing the clutch back to the OEM but I'm not really sure how much it will cost.... any ideas?
Also, should I change the fly wheels/pressure plate too when going back to OEM?
Why would you pay money to have the OEM clutch put back in?....
Regardless it should cost you between $500-$800 to have done.
If your going to do the replacement, you should replace the components while it's open.
JMO
Tim
JMO
Tim
Clutch, PP, and Throwout will run you about $350 from GoFast. Probably close to $500 if you buy from a dealer. Add considerable amounts for labor. I'd say you'd be closer to $1000-$1200.
I'm wrestling with the whole new clutch issue myself. I'm buying from GoFast and putting it in myself.
i spent a total of $1,300 on new OEM flywheel, pressure plate, clutch, throwout bearing, pilot bearing, installation, alignment. reason why i had so much stuff replaced was because all the components were just GONE, i couldn't press the gas more than half an inch while cruising without having the revs just fly up. installation was approx $550.
honda dealership wanted $1,400 just for installation if i provided the parts, lol
Originally Posted by icethug81,Jan 19 2006, 11:19 AM
Wow, that's a lot~ what happened? was it caused by hard driving style or just weak parts? Also, r u using all oem parts or aftermarket?
Personally, i went with HTG's clutch kit. comptech flywheel, ACT PP, oew disc, and throwout bearing. including install, i paid just under 1300. However it doesn't look like HTG is selling the clutch kit anymore....hmmmmm
http://www.hardtopguy.com/store/customer/p...=234&cat=&page=
