Replaced fuel pump car wont start
Hi anybody got that trouble after fuel pump replacement..
I reconnected the hose and the plug connector,pump is pumpig at ignition...
Whats wrong..car was startin with old pump..
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
sounds like it especially if its priming.... although you could check your fuel pressure by pulling the regulator and seeing how much goes in a cup... should be about 1/3 full in a 20oz cup
Okay finaly it started..but did not solve my problem..
My problem is car is dtalling at idle after 5 min when cold..and im not able to restart it after few hours...
Spark plug are black . And brand new
Checked coil..
Fuel psi is at 43 while engine running
And my air fuel ratio at idle is at 11.3...
What my problem...long time i try to solve the problem...tired..
On road car wont rev
Over 4k..he is bugging pver that
Checked coil..
Finally..it was the crank sensor misconnected....still have misfire while running ..wideband show lean when i get the misfire..
I hear a poop from exhaust when it does miss...
Thanks
Thanks
