Replaced diff fluid this weekend
Old 10-02-2006, 08:39 AM
SilverDC2 AP1's Avatar
Default Replaced diff fluid this weekend
I replaced the different fluid yesterday, everything went smooth, i let the fluid drain 40-45 minutes, a drop would fall every 30 seconds or so.
i think it was the original fluid it had a lot of shavings practically black, i bought the car with 17k now im at 24k, from honda.
it didn't take the whole liter of just under, did i not let it drain enough? i filled til it would drain out, i would wait and refill and still it would pour out slowly.
The car was leveled,
Old 10-02-2006, 08:44 AM
Hockey's Avatar
Diff capacity is 900ml, so less than 1 qt. You can overfill it slightly if you leave the driver's side jacked up (with a jack stand) so that the fill hole is a bit higher.
Congrats on the DIY attempt. As you can see that fluid gets pretty nasty so be sure and change it early. I go by the
"severe" schedule which states every 15k miles.
-Hockey
Old 10-02-2006, 08:48 AM
i just didn't have the 23mm wrench laying around, next is the tranny, probably has the original oil also,
Old 10-02-2006, 08:49 AM
JackS's Avatar
I just looked in the OM and the total change is about 3/4ths quart. It sounds about right.
At your next change warm it up a little by driving beforhand which should allow for max removal of the old fluid.
Old 10-02-2006, 08:51 AM
i drove for 5-10 minutes before hand. thanks for the tip though
Old 10-02-2006, 09:25 AM
SpitfireS's Avatar
Hockey Posted on Oct 2 2006, 06:44 PM
A little extra doesn't hurt.
SilverDC2 AP1 Posted on Oct 2 2006, 06:39 PM
I replaced the different fluid yesterday...
Replaced it with what?
In your climate the recommended SAE 90 / GL-5 would be perfect
Old 10-02-2006, 09:33 AM
djpeak10's Avatar
hockey what diff fluid do you use? I used the mobil 1 gear lube 75-90 I believe do you have any experience with that stuff?
Old 10-02-2006, 09:39 AM
I replaced it with, mobil 1 gear lube 75-90, i wanted to put redline fluid, but all the placed were out of 75-90,
Old 10-02-2006, 09:43 AM
K-Lo's Avatar
i replaced mine last Saturday with Mobil 1 75W 90 (almost entire bottle)following xviper's DIY
https://www.s2ki.com/forums/index.php?showtopic=99995
thanks xviper!
and all went well. I noticed the car handling has changed. the rear grips more (is it just me thinking this?) and accelerates better. any thougths about this?
Old 10-02-2006, 09:48 AM
It feel a little smoother, less "clunk" i dunno. its probably in my head.
Quick Reply: Replaced diff fluid this weekend
