Replace retainers 03
While i am in there is it worth replacing the springs, seals, and ?? Anyone have a kit for this they recomend?
Thanks for you input
Thanks for the input guys. Spoke with Jeff from science of speed and he feels the cracked retainer problem was with the 00-01 models that the 03 was ok. Anybody else notice this? I will pull the valve cover and do an inspection first now.
What do you mean "while I am in there"?
Are you pulling the head? are you just changing the oil??
I am confused now.
I thought you were doing a valve job or something.
If you have not overrevved or have a ton of miles I dont know.
I always feel better safe than sorry on a track car.
I am confused now.
Sorry what i meant was while i was replacing the valve retainers. Thinking of replacing seals, maybe springs, thinking timing chain tension is that a good time to get to the adjuster to replace it. even if i just replace oem springs or is that a waste of money at 60k miles. I do not intend to remove the head.
definitely replace the retainers. i just replaced mine in my 02 and everyone of the intake retainers was cracked. i have a thread going in the north texas forum with pictures: https://www.s2ki.com/forums/index.php?showtopic=749003
you cannot truly tell if they are bad by inspecting them with a light and mirror. all of mine showed no indication of the cotters sinking but they were all heavily cracked and desperately needed to be done. all i can say is that it is worth the time and effort get them done. i replaced mine with AP2 retainers as they are tappered more at the top and a bit thicker. im pretty sure if i had hit the track day that was planned i would be buying a new motor right now. my car just came to around 80k and i have never had a definitive over rev, but i am the second owner so there is no telling what they did. its a small price to pay to ensure you do not grenade your motor.
hope this helps you.
Hardtopguy provides all the parts as a kit. Just make sure to order the AP2 version.
http://hardtopguy.com/store/product.php?pr...7&cat=53&page=1
riceball777
04-14-2014 07:32 PM
