Removing thread locked bolt
I need help removing thread locked bolt from my PWJDM Intake.
I tried removing it using allen key but it just didn't move and if I force it, I might just strip the bolt.
Can any of you guys help me?
Thanks in advance
Erik
Thanks in advance
Erik
You need heat, and lots of it. Threadlock is rated based on how much heat it can take and stay bonded. Depending on the size of the bolt and type of threadlock (blue/red?) will determine how hot a heat source you need. Most red threadlocked bolts can be done with a small pentorch. It may also help to dremel a groove in the head so you can use a flat blade screwdriver for more worry-free leverage. Of course you will then need to replace the bolt.
Originally Posted by Gigdy,Oct 8 2009, 02:54 PM
A thread locked allen bolt sounds like a terrible idea.
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Threadlock on an exhaust? Doesn't sound right. Loctite melts at a pretty low temp. It may just be seized, or a locking nut. An impact bit and a low torque impact is your best bet.
Can you use vicegrips to grab the outside of the bolt. If not try shocking it off with a allen key, and if you stuff it use a mig welder to weld an old bolt onto the end of the bolt. Gives you something solid to grab it with, and some heat to loosen the bolt.
