Removing start button
I've got the audio panel off and disconnected, but I can't figure out how the start button barrel comes out. On the barrel there is a copper looking tab that looks like is should be pressed, and the barrel would slide out, but it won't budge. I also read somewhere that they screw out, but I don't see how they can.
Can anyone help ?
Thanks,
Simon
Can anyone help ?
Thanks,
Simon
in my service manual, it showos its held in by a clip of some sort. i dont have experience with it personally, im just going off the diagram. dooesnt meantion anything about it screwing in
Originally Posted by krikke_s2000,Feb 16 2009, 01:14 AM
i can just push mine out if i jigle it a bit
I didn't want to put too much force on it without knowing exactly how it comes out.
Any other ideas ?
Push the clip or clips on the back and push it forward. I can't remember if it's a clip or two. Regardless, don't apply force if it's not moving. I remembered it pushed right out once the clip(s) are pressed.
Does the outer (front) piece of the panel need to come off first ?
It's got a number of plastic tabs around the edges.
Thanks,
Simon
Got it out - thanks for the assistance.
For anyone else with the same problem, there is a metal lug on the side of the barrel 180d from the press in tab which is hard to see. You need to stick a screw driver down there to pry it over the plastic surround, the push the tab and it will slide out.
S2Bray (03-13-2021)
It is held in by little tabs on each side, lightly pry them back and it'll pop out. Be careful if you take it apart that you put it back 100% the right way, I didn't and my starter engaged everytime I stepped on the clutch
