removing the sensor from the cat
sorry if this is already somewhere, I'm kind of in a pinch.
I'm in the middle of installing my J's 70RR (thanks Ken!), and I can't get the sensor out of the cat...
does it screw out?
does it pull out?
any and all suggestions would be appreciated...
does it screw out?
does it pull out?
Originally Posted by breakneckS2k,Feb 28 2008, 10:02 PM
nevermind got it. mods close
no. mods don't close! don't close!
I have another issue.
Will I regret it if I remove that little cross-member that's right in front of the differential?
but thanks hondafied for the info!
hypothetically, if I get the crossmember off and don't put it back, will it be totally devastating?
b/c I can't get the oem exhaust out without taking it off, but I don't think I can get it off w/o breaking the bolts...
I swapped my exhaust a bunch of times lately and finally snapped 1 of the bolts there (had some salt corrosion), a quick run with one of the good bolts to a mechanic or home improvement store will get you replacements.
mobile chicane
01-18-2012 05:22 AM
S2KballinOut
24
04-21-2010 08:57 AM
