Removing drive shafts
I'm trying to remove my right side drive shaft and I'm not sure which part of the hub I have to take off to get the axel out.The diy on here says to take the lower a arm ball joint off but the shock is connected to that a arm also so would I take off the bolt holding the shock? Do I have to take off the tie rod ball joint to swing the hub to get the axel out?
Dont touch the shock.
-remove 10mm bolt holding abs sensor in and remove abs sensor from knuckle. If you dont, you will break the wires internally when you pull out on the spindle.
-remove 36mm nut on axle
-remove 17mm nut on bottom ball joint
-using ball joint breaker, pop lower ball joint
-remove 6 bolts hold axle to dif
-swing knuckle outwards, remove axle spline from hub, then slide axle out of dif and out of the car
kgregg
05-12-2018 08:35 PM
