Removing calipers
Is there a way to remove them without losing fluid?
i know a guy that used to put something soft around the liine and barely pinch the line with some vise grips and it worked well but im kind of weary about that. looking for any input! thanks
Are you removing them to replace rotors etc.? If so, you don't need to disconnect the brake lines. Unbolt the caliper and hang it with a bungy so there isn't any tension on the line.
If you absolutely need to remove the caliper you are going to lose fluid and ultimately need to bleed your brakes. Brake fluid isn't expensive I wouldn't be worried as long as I was keeping the line up to minimize fluid loss.
Originally Posted by metros,Jul 5 2009, 09:55 AM
I wouldn't let it "Drain out" as you don't want the master cylinder to go dry. Just minimize the amount of fluid lost and replace with whatever fluid you planned on using.
thanks
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
You can pinch the line, but it's not recommended since you can damage the brake line. A rubber brake line is made kinda like a tire sidewall...it has a fiber belt running through it to strengthen the rubber. If you pinch, you can break that belt...then you will see a balloon like blister pop up at some point indicating you are dangerously close to losing all your brake pressure in the middle of a braking maneuver.
Originally Posted by downloader,Jul 5 2009, 04:27 PM
I got the answer
Take a tire valve and shove it into the banjo hole. end of leaking
![light.gif](https://www.s2ki.com/forums/images/smilies/light.gif)
