Removing the block without disconnecting AC
I just put a clutch in mine. I had to drop the cradle 3". I unbolted the compressor from its mount so I didn't have to evacuate it. You should be able to do the same. Just watch carefully whn pulling the block to make sure it clears.
The fun part will be getting the compressor back on it's mounts, as it goes under the H20 pump and alternator. BTW, unbolt the entire H20 pump housing from the block, not just the front part of the pump.
