remove rotors?
#31
Originally Posted by xviper,Aug 11 2005, 11:12 AM
From that link:
After this very short "disclaimer", he procedes to only expound upon the shedding of brake pad material topic.
#32
Originally Posted by pantyraider,Aug 11 2005, 11:30 AM
but Smith is well known for his books on race car engineering. I doubt that he'd have an alterior motive...
OK, I'm not arguing the issue of brake pad material causing pedal pulsation. I just don't want people to dismiss rotor warpage as a result of improper rim mounting and since the original poster has indicated this didn't happen in his case, I'm stepping off this bus at this stop.
Carry on.
#34
And, I'm not sure if that article is actually a Stoptech sourced one, unless Carroll Smith works for them, but Smith is well known for his books on race car engineering.
His books on race car engineering are indeed excellent.
When I look at an S2000 front rotor, I just don't think it will "warp". The internal vanes just make it too stiff of a structure.
#35
Originally Posted by mikegarrison,Aug 11 2005, 12:46 PM
Carroll Smith no longer works for anyone. He died in 2003.
I met Mr. Smith in 1999. Carroll Smith along with Carroll Shelby played a major role in Ford's success at Le Man's in the 60's. He was a cool dude.
#36
Originally Posted by pantyraider,Aug 11 2005, 01:30 PM
The sentence after the one you quoted:
" They are also subject to frothing from high frequency vibration, which gives a soft pedal. Soft brake pedals may be OK in non-high performance cars (in fact, most drivers accept mushy brake pedals as normal) but they are not acceptable in any situation where the driver intends to modulate braking at high force values."
I don't think he's recommending using DOT 5 fluid ...
#37
Originally Posted by Carroll Smith
MYTH # 5 - BECAUSE THEY ARE NON-HYGROSCOPIC SILICONE BASED BRAKE FLUIDS ARE SUITABLE FOR USE IN HIGH PERFORMANCE CARS
DOT 5 fluids are silicon based and are non-hygroscopic, which is good. They are also subject to frothing from high frequency vibration, which gives a soft pedal. Soft brake pedals may be OK in non-high performance cars (in fact, most drivers accept mushy brake pedals as normal) but they are not acceptable in any situation where the driver intends to modulate braking at high force values.
F20C PWR
10-25-2007 12:39 PM
