Reducing Drone
Sure you don't have a leak or something? What RPM's are you cruising at that you have this drone? I have the same exhaust and it doesn't drone at all, a little bit decelerating from 4-3000 but if I am cruising there really isn't any drone
maybe its a leak... doesnt sound like any exhaust leak ive ever heard tho. I ordered new gaskets and they're on their way because the gaskets i got with it were pretty beaten up. or maybe I dont have a clear concept of what "drone" actually sounds like, but I just know that any time you give it any throttle it gets really damn loud and deep in the cab to the point my ear drums hurt
with the stock exhaust I used to cruise around 3-4k, but with the sparrow, to keep the noise down i try to keep it around 2-3k, that seems to be the quietest range. low rpms (below 5k) are very loud and deep, but at wide open throttle, once in vtec, the drone goes away and its a very clean exhaust sound, much quieter from inside the cab than it is at low rpms. is this an indicator of a leak?
I tried the exhaust wrap and could not tell any difference with or without it. Extending the exhaust tip 3 inches made a noticeable difference, but looks a little odd.
While I certainly get the humor in your comment, I think there's still good reason to justify this exhaust.
1st, I believe it adds much more than 5hp. Most dyno tests show 10-12.
About 15-20 lbs of dynamat is needed, not 40.
The exhaust weighs much less than the stock one.
And as for profit, the stock one certianly doesn't sound anything like this:
http://www.youtube.c...h?v=uJxCQaHeepU
All this being said, the exhaust certainly has some drone. The last clip in the video posted above demonstrates some of that decel drone. Just from an acoustic standpoint, under acceleration, I honestly think it sounds good enough to put up with the drone drawback.
*edit* Don't know if it makes a differnece much but mine is a single
