Redline MT-90 / MTL Mix
Old 02-18-2003, 06:22 PM
  #21
StwoK's Avatar
[QUOTE]Originally posted by pfb
[B]
I picked up a quart of MTL and MT-90 earlier today. I'm planning on putting in the full quart of MT-90, then however much MTL fits in with a slight overfill.
Old 02-19-2003, 07:52 AM
  #22
PilotChris's Avatar
I'm also planning on mixing the MTL and MT-90. I'll probably get around to it this weekend.
My question is, if I don't autocross and only run my car from time to time, how often should I change out this fluid?
Old 02-19-2003, 08:01 AM
  #23
Former Sponsor
Gernby's Avatar
[QUOTE]Originally posted by PilotChris
[B]I'm also planning on mixing the MTL and MT-90.
Old 02-19-2003, 01:10 PM
  #24
Venomous S's Avatar
[QUOTE]Originally posted by gernby
[B]I left my car out of the garage last night, since I wanted to see how well the tranny shifted cold.
Old 02-19-2003, 08:10 PM
  #25
pfb
pfb's Avatar
Put in 50/50 blend of MTL/MT-90 this A.M.
Was a pretty crisp day, and cold shifting was fine after 60 seconds or so. Had no problem getting 2 qts in by lifting the drivers side with a jack, putting in front and rear jackstands, and filling with a small gear oil pump in that position.
I did level out the car while draining, though, to remove as much of the old fluid as possible.
For the rear end, red-line recommended against shock-proof for a street driven car; they claimed the "gel structure" that they use to get it to cling to the gears gives it less than optimal cold weather characteristics. So I used synthetic 75W/90, Mobil one. The factory fill diff oil that came out didn't look too bad, even after 20K miles.
Old 02-21-2003, 08:12 PM
  #26
StwoK's Avatar
Lifting from the driver's side sounds like it should be easier then lifting the back of the car up to put 2 qts. in. I'll try that the next time. Thanx!
Old 02-22-2003, 03:36 AM
  #27
Former Sponsor
Gernby's Avatar
I am starting to wish I had tried a 75% MT-90 / 25% MTL mixture. I have driven about 400 miles with the new fluid, and I've noticed that the cold shifting is still great, but it doesn't really get to a "perfect" feel, like it did a week ago, or like the straight MT-90 did (fully warmed).
I still think this is a good choice for cold climates, but I will go back to straight MT-90 as soon as winter ends.
Old 05-25-2009, 05:52 PM
  #28
INTJ's Avatar
MT90 is just too sensitive to temp for me. It has to be 90+ and a warm engine for it to feel right. I am running GMSM FM and it feel distinctively better than the Honda II.
Old 05-26-2009, 03:26 AM
  #29
IMP
IMP's Avatar
It's been 6 years since this thread was made... any new progress on blending or finding a better mix?
Old 05-27-2009, 07:07 PM
  #30
INTJ's Avatar
I think that a 75-25 Mt 90-MtL should work well exc in cold climates (Rockies or canuckistan, go MTL) I'm running GM Synchromesh Friction Modified and I love it over Honda MTF II.
Croc
03-15-2012 02:03 AM
TRDLiquidSilver
06-06-2008 07:40 AM
OriginalFive
07-07-2005 09:43 PM
golfnut311
12-01-2002 03:07 PM
OneQuickS2K
06-07-2002 01:51 PM
Quick Reply: Redline MT-90 / MTL Mix
