Redline MT-85 tranny fluid
#21
Not sure why you want such thick oil in the transmission. Honda states:
but would they know?...
-- Chuck
If Honda MTF is not available, you
may use an SAE 10W-30 or 10W-40
viscosity motor oil with the API
Certification seal that says ‘‘FOR
GASOLINE ENGINES’’ as a
temporary replacement.
-- Chuck
#22
Yea, I don't either lol..
-- Chuck
-- Chuck
Honda's MTF is garbage in my opinion. I ran it in my Accord 5-speed, and a week later the bearings were making noise and it shifted like complete crap. Put GM synchomesh friction modified and it was very much improved afterwords. Maybe on a brand new car it works well, I don't know. But like I said, I'll post back tomorrow and let you know the results for my particular car.
#23
Originally Posted by Chuck S
Not sure why you want such thick oil in the transmission. Honda states: but would they know?... -- Chuck
[attachment=75681::]
[attachment=75682::]
#25
I had extra MT-90 once and called Redline to ask about this fluid in our tranny. He told me it was too thick for our transmission and advised me what I could do is fill the first QT with MTL and top it off with MT-90. I think that was before MT-85 was offered as I don't recall that being an option at the time.
#26
I've been using MT-85 in my car for about a year. It was a little notchy until after a couple track days, but is smooth now... And I'll be changing it with more MT-85 before track season this year. I might add a small amount of MTL when I replace this time.
#27
Update after driving it this morning to work in 38 degree temps...pretty good so far! It shifts pretty well so far, better than it did when I picked the car up a few weeks ago.
#28
I'd like to try Redline MTL, I've always had good luck with it.
When you change fluid like this it sometimes takes a couple weeks of use to get it to settle to a homogeneous state. The new fluid will have to mix with the old fluid and plate up on the metal surfaces, after a bit of use the fluid viscosity and additive mix tends to arrive at a happy place. You may find better results with use.
#29
Personally, I've used the original Honda mtf, the newer green Honda mtf, Redline MTL, and GM Syncromesh with Friction Modifier. GMSMFM is by far the best feeling I've ever had, but I change it about every other oil change to keep it feeling good. Seems to break down quite quickly. That's all I use anymore. Redline MTL definitely felt better than either of the Honda products, with the green one feeling the worst.
#30
After driving the car throughout the day getting up to temperatures of 63 degrees, the MT-85 made a very noticeable, positive difference over whatever the car had in it before. I have also used Honda mtf and GM Seyncromesh with FM. The GM product has felt the best to me also in use of other Hondas. I was thinking about running it in this car but thought it might be too thin given the amount of miles and unknown wear. I am pleased with the MT-85 thus far though, and Ive only driven about 100 miles on it so far.
