Recommendations for Newbies
Hi Gang! Been away a long time, and found my Inbox full of "what oil to use?" type questions. I do not want to appear to be stuck up, but I cannot answer every one of those Q's with individual responses, so i posting my Signature which has lots of recommendations for the products I use and stand behind.
BTW, I have all of 2600 miles on my car, which reaches its warranty expiration in December!
A few additions:
1) Additives:
For break-in if you have drained the factory fill, I now prefer Valvoline Synpower Oil treatment over MaxLife Engine protector (MLEP).
I like what Lube Control has formulated. I do not have the URL, but it is easy to find on Google. LC attacks deposits rather than being a "slickmeister". But it is very effective, and the chemistry is rock-solid.
2) Tranny fluid:
Still very much like GMS-FM. It is batting 100% on the 6MT 3rd Gen Acura TL's on acura-tl.com.
I also have had very good luck with MTL-P from www.specialtyformulations.com. Tell 'em RR sent you. The damn stuff is purple, though, which I hate. I like stealth.
Hope everyone is well. I was astonished to hear the 2006 is the end of the line for the S2000 as we know it.
Does anyone know the S/N of the last S2000 made at Tochigi? I wonder if they will fetch more than the later (Suzuka?) cars made elsewhere.
A few additions:
1) Additives:
2) Tranny fluid:
I really hope it was an April Fools joke. But now that I'm thinking, if 2006 is the last model year, do they continue making them until 2006 is over or do they stop at some point during the year?
Andre
Andre
Andre
Andre
It won't be long anyway before everyone finds out. The new brochures tend to surface around Sept., maybe sooner. If we don't see any by then, I guess we have the answer.
Road Rage!! Glad to hear from you! And yeah, that was a photochop in that article.
also, RR, the website for lube control is www.lubecontrol.com
RR: Any particular reason for the change in opinion?
RoadRage, FYI if you contact MolaKule directly you can order MTL-P without the dye.
tron1: the reason for the change is this: compare the Virgin Oil analysis of both:
VSOT: http://theoildrop.server101.com/ubb/ultima...11;t=000297;p=1
MLEP: http://theoildrop.server101.com/ubb/ultima...c;f=11;t=000131
FYI Lube control not only acts as a cleaner, but it is also an antioxidant and friction reducer.
Forgot to mention Specialty Formulations also has a rear differential fluid, HDS-5 (75w90) which I currently have in mine. Have no problems with it so far and will get analyzed when it comes out (December).
They also make a "racing" diff fluid, HDS-R which I believe is around a 75w115 with extra extreme pressure additives. Check the spec's for their fluids here:
HDS-5 http://www.specialtyformulations.com/HDS-5.htm
HDS-R http://www.specialtyformulations.com/HDS-R.htm
I'll be interested to try HDS-R next time around.
