Recirculate my Catch can. before or after BOV?
Ok, I installed this catch can a few weeks ago, and now all I smell is gas/oil when driving my car.
I'm gonna replace this catch can with a closed system one that re-routes to the intake charge pipe, instead of having the breather filter on the can.
So I have to drill a hole in pipe before the throtlebody and thread it for a fitting. no big deal.
But does it matter if I put the fitting before or after the blow-off valve???
off topic but is you catch can mounted to the cross member using a t-bolt clamp with a mounting hole on each side...cause I was thinking of doing the same...just need to get the 90 degree drill attachment to drill the cross member...wanna confirm this before I go ahead and do it...thanks
