recently installed buddy club coilovers.. help with noise!
I notice a clanking noise coming from the rear left coilover.. i assume its coming from the pillow mount.. anybody know how to resolve this? is it normal to have noise from running pillow mounts?
I've had my Buddy Clubs on for about 15 months and there has been no noise associated with them. Check over your install again to make sure everything is tight.
You should put some pre-load on them. The noise is probably from the spring moving after you hit a bump. If you put some preload on them it might take care of the spring movement.
