Reccomendations on brands for next upgrades
Hello all, I will keep it short and simple!
I am getting ready to buy
- a new clutch for my S, since the stock one is really not fun coming out of first with the little bit of slipping that occurs.
-combat heat soak, I have a cooling plate already but want radiator and maybe fan reccomends?
-Lastly, brakes. I am in need of new brakes but want an upgrade over oem.
Thanks!
Thanks!
Thanks!
Thanks!
Do you track? Do you use ep tires? If no to either, just stick with stock brakes. You won't increase stopping power with a bbk, just increase stopping repeatability (dissipate heat fast enough to keep up with track work).
If you want to get rid of heat soak, wrap your headers, and use gold reflective foil on the part of your airbox directly in front of the radiator and next to the engine block. Or get a vented hood, cutting the oem hood doesn't really work that well unless you can guide the airflow you're venting.
silvermonster
06-13-2020 06:41 PM
