Rebuilt f20c1
There was someone that tested this and the result was unless you change the valve springs then there is no reason to baby the engine and it actually makes more power if you push it hard. Valve springs have a weird coating that breaks down, some of them do, and it goes into your oil and can f@#k shit up. Scored cylinders is a bunch of bull.
You drive it soft, for about 100-150 miles, making sure to shift through every gear, highway driving is not recommended because you stay in a single gear for too long, when decelerating, down gear each gear and release the clutch so it can grab the gear and rev the motor, it helps seat everything, don't just skip from 5-6th straight to neutral and brake. After 100-150 miles a good break in method is to go from 20-30 mph in 3rd, run 3rd gear all the way out, then let off and let the car decelerate back down to 20 mph or so, do this until you don't see anymore smoke caused by oil coming from the exhaust, then you know your rings have seated, everything else should be good to go as well. Was told this method by a certified Honda technician. Worked for me
Originally Posted by jl56tc' timestamp='1371155600' post='22606920
[quote name='s2000maniac' timestamp='1371144124' post='22606416']
I read somewhere that's its better to break the car hard. Redlining a few gears.
[/quote]
I also like the MotoMan's method. Basically, vary RPM's a lot, and lots of WOT in low - mid rpms.
My favorite oil is from Joe Gibbs Racing. These guys know there stuff. I've been using their LS30 oil in three different cars. An Lake Speed, their oiling expert, is one of the most knowledgable guys in the country about oiling engines.
I broke my engines in with the FR30 oil. I also happen to have a case which I'd sell you cheap.
http://www.drivenracingoil.com/news/...break-in-oils/
Look at the facts: FRM.
That stuff NEEDS slow break-in.
Forget about chrome cylinder wall break-in methods, they do not work well for FRM.
IOW: follow what AP1Driver posted.
In addition: use crappy el-cheapo dino 10W-30 oil for the break-in period and do not add anti-wear additives.
Break-in IS wear.
Break-in IS wear.
It's not really science. put some good ole Mobil 1 In & follow the owners manual. first 600mi. no full throttle starts, do not exceed 5500 rpm for 600 mi.(no V-tec)and go
