REBUILDING MY F20C
Old 01-19-2021, 01:28 PM
  #31
Kevinthenube's Avatar
Default Update in your engine.
Originally Posted by elna9ry
I'm currently rebuilding my engine as it was damaged thanks to my brother who apparently over pushed the car with low oil, the result was damaged bearings, crankshaft (might be able to grind it, not sure though), connecting rods, pistons and cylinder liners (the whole rotating assembly).
I need your help guys in choosing aftermarket parts that will improve both performance and reliability/durability WITHOUT increasing the displacement or increasing the compression beyond 12.0:1, keeping it naturally aspirated for street/track use.
I have been told to consider lightweight performance engine internals which will help with the performance. Honda OEM parts are not cheap hence aftermarket performance parts makes sense. Please keep in mind that my budget for the full list above is maximum $ 4000.
If Honda OEM is the way to go for any of the above parts, please let me know. Thanks in advance.
It’s been years since this thread was made. Were you able to rebuild your engine or what did you end up doing?
Old 01-24-2021, 11:55 AM
  #32
licelsior's Avatar
InlinePro has a service of redoing the FRM lining if your going with a OEM rebuild.
PureFunction
04-01-2015 09:38 PM
Tom04S2000
06-30-2012 04:50 AM
OneInsaneS2000
05-16-2003 02:51 PM
STL
07-21-2002 09:58 PM
Quick Reply: REBUILDING MY F20C
