Rear window hitting the roll hoops
When going over bumps, the rear window sometimes hits the roll hoops which is annoying. It's a Robins top. Is there an easy and inexpensive solution to this?
check the position of the rigid straps. They bolt one stud back from the front on the rainrail studs. If they are on the front stud, the window will hit the roll hoops.
