Rear wheel will not move!
#21
Originally Posted by gsp' date='Feb 1 2005, 12:39 PM
You have a seized bearing in the hub,,,,that is why someone took out the axle,,, so they could move the car.
#24
Originally Posted by gsp' date='Feb 1 2005, 10:55 AM
Yes, I should have said: "as an attempt to move the car".....odd that the axle is gone
#25
Without the axle installed there is nothing holding the bearing together. Moving it around without the axle will cause the bearing to seperate allowing the wheel to wobble. If it wobbles enough it will cause the ABS cog to take out the ABS sensor. It will also cause the brake rotor to not ride in the brake caliper correctly. The miss alignment between rotor and caliper is likely whats causing the problem.
#27
bgoetz
11-16-2014 09:03 PM
TougeHorseman
41
06-07-2012 09:18 PM
