rear wheel rubbing noise?
Is there a reason your replacing the caliper instead of rebuilding it?
If you have access to an air compressor, you can blow out the piston. Use a small block of wood to catch the piston and don't get your finger in the way. The rest is self explanatory. Make sure the caliper is clean, then use brake fluid to reassemble the piston with the new seal. Just a thought.
